Access Motor AX-700 EFI
Δημοσίευσηαπό Lukas » 31 Δεκ 2010, 12:33
Access Motor EFi AX-700 Key Features:
-Liquid-cooled
-Four-stroke engine
-Light weight: the best power-to-weight ratio of utility model of Access Motor
- Electronic fuel injection provides a perfect fuel/air mixture, for instantaneous cold starts and optimal
performance in all conditions and at all altitudes
-Bosch electronic fuel injection with 44mm bore and throttle position sensor means easy cold starts and
flawless fuel delivery in nearly any condition
-Transmission - Centrifugal clutch maintains constant belt tension for reduced belt wear
- Downhill engine braking
-Ceramic-composite cylinder liners provide outstanding durability and heat dissipation; forged piston which
is light and strong
-Gear-driven crankshaft balancer shaft and rubber-damper engine mounts reduce vibration
-Straight drive shaft for reduced friction, vibration and maintenance
- Sealed drive case keeps out water and debris to help prevent belt from slipping
-High-capacity aluminum radiator with fan-assist delivers maximum cooling efficiency and is positioned high
in the frame for optimal protection (can be used for 450 c.c. range)
-3 Ways locking lets you switch between 2WD, limited-slip 4WD and fully locked differential 4WD – all with
the simple push of a button
-Override button
-Electric starting with disks torque-limiting damper assembly to protect the starter motor
-Full independent long-travel four-wheel suspension and five-way preload-adjustable shocks provides
maximum ground clearance for great comfort over rough terrain
-Four-wheel hydraulic disc brakes serve up consistent, long-lasting braking power under all sorts of nasty
conditions
-Multi function LCD display with speedometer, odometer, dual tripmeters, hourmeter, transmission position,
fuel injection information, High RPM warning indication, 4WD status, Diff Lock Indicator, fuel gauge, gear …
-Anti-thief locking system
-2 seat homologation
-LED front Daylight arrangement
-LED braking light
-Front and rear racks with special, extra-durable wrinkle paint finish
-Waterproof storage at front and storage compartment under the seat pad
-Non-slip seat pad, large seat for all0day rider comfort
- Lower seat height for quick steering and maneuverability
-Optional:
Skip plate: full-length composite skid plate deliver maximum underbelly protection
Lukas
Τοποθεσία: Salonika
Δημοσίευσηαπό Lukas » 31 Δεκ 2010, 12:57
Lukas
Τοποθεσία: Salonika
Επιστροφή στο Quads
